1 (edited by Reese 2024-09-04 19:13:02)
Topic: ARC USB function request
Don't know where to put this topic really, but here goes.
I have an UCX II and recently bought the ARC USB.
Is it possible for devs to add the encoder increments for headphones like already available for main-out?
i.e. When selecting a headphone volume, the encoder makes steps of 1.5dB. Would be nice to have 0.5dB and/or 0.1dB as well.
Re: ARC USB function request
It's not exactly the same but do you know about the "fine" control. -> Hold down shift and control the desired fader.
Audio AG Support
Yes I do, but then I'd need to use both hands... Increments are 0.1dB using shift btw, so it's an option to dial in.
The encoder on the UCX II itself uses increments of 0.5dB when adjusting the headphone volume, so I fail to see why the encoder on the ARC has been deliberately set to 1.5dB for the same function.
Nobody seems to use this ARC function, I guess..
