1 (edited by centrala.sound 2024-09-24 09:55:04)
Topic: MADIface Pro + M-32 DA + M-32 AD possible?
Hey, I want to configure ADDA system where MADIface Pro would be master instance connected to PC. Is it already possible to connect M-32 DA and M-32 AD with those interface? I thought I need two MADI Simplex cables - one for MADIface Pro -> M-32 DA, one for MADIface Pro <- M-32 AD. But would that work together? Does it gets proper clocking for all devices?
Sorry, but Im new in MADI world.
2 (edited by waedi 2024-09-24 10:59:51)
Re: MADIface Pro + M-32 DA + M-32 AD possible?
Hi CentralaSound
You would have to connect those in a daisy chain, open the cables connectors housing lets you separate the fibers.
Daisy chain means round-trip cabling, always from output to input.
Clock is no problem. Make both M-32 to Madi in the clock section on the front panel. The Madiface Pro has to be clock-mode internal.
Hi Waedi,
thank you! So  should go MADIFace Pro OUT to M32 DA IN, then M32 DA OUT to M32 AD IN, then M32 AD OUT to MADIFace Pro IN?
As for cable - I can separate Duplex MADI right?
