Topic: ARC USB as Controller for Logic Pro (MDS Script)
Hey,
i would like to share my MIDI Device Script for Logic.
With this, you can easily use the ARC USB as MIDI Controller within Logic.
Note, that ARC USB has to be disabled in TM first, as it otherwise interferes between with Logic and TM!
Read the pdf inside the zip first!
https://cloud.sndtek.de/s/WyfKcJeXKoL5F … 0v0.1b.zip
On Sequoia - as usual security paras by apple - it will try to move the pkg to trash, as the installer is not signed with a dev cert.
Just cancel (do not move to trash), open Settings - Security Settings - and allow it to be executed. Enter your password and the installer should be done.
Any ideas, enhancements, questions are welcome.
Happy controlling your Logic with the ARC USB :-)
maggie33
“Do It For Her”
Re: ARC USB as Controller for Logic Pro (MDS Script)
That's awesome!! Faintly gong to check this out..
Thanks so much for sharing.
Matt McKenzie-Smith (UFXII, UFX, Babyface) MacStudioUltra OS13.2.1
Thanks for trying out, Matt... Let me know if sth doesn't work as expected/described or you have any questions.
“Do It For Her”
