Topic: global mono button and snapshots
Hi I can't associate a snapshot to the mono button in the global main. please how can I enable/disable it through a snapshot?
Re: global mono button and snapshots
Can you store snapshots with other adjustments, faders or so ?
Include the buttons as well.
yes snapshots works with everything but the main global control like dim and mono
4 (edited by waedi 2024-09-27 22:49:33)
Ah ok I messed that up with global Mute and Solo button.
You are right, the Mono, Dim, Recal buttons in the Control Room are not part of Snapshots, they seem to have a higher priority.
By a quick look into the user manual I could not see why the buttons are excluded, the main-out fader is included.
so is this how it's supposed to be? there's no way to associate a mono main out to a snapshot?
Workspace includes Mono (don't know if that helps though).
7 (edited by waedi 2024-09-29 22:50:20)
Yes, it is supposed to be this way.
Control room and Snapshots are two different things.
Snapshots are for flipping monitoring-mixes.
The control room may want to listen mono sometimes without disturbing musicians during recording.
Do you use any controller device ? Wich one ?
