Topic: SPDIF lock
When using the UCX as a tool to test SPDIF transfer, I want to better understand how the PLL lock and the LED signal on the front panel function.
I've observed that when I connect optical or coaxial in a loopback, the SPDIF and/or ADAT LED remains solid. In this setup, DeltaWave consistently measures a bit-perfect result of 99.96% through the physical loopback.
However, when testing with different SPDIF sources, including CD players as DUT, the LED blinks 2-3 times at roughly 2-second intervals. The recordings sound fine, and DeltaWave results show good average clock drift but rarly better than 20% bit accuracy. Upon closer inspection, there are occasional periods of drift, but not at the same 2-second intervals.
Is this expected behavior? Or are there settings where I can set the sample rate and clock source to help mitigate the blinking LED? I’ve tried Fireface ASIO with Cubase and WASAPI with DeltaWave/Adacity
tia
