Topic: Only see input 1/2 from UCXII in Logic Pro for iPad
When I connect my UCXII (CC mode) to my iPad Pro M4 with Logic Pro for iPad, there are only two available inputs showing up in Logic, namely input 1 and 2. Why can't I see the rest of the inputs? Anyone else experienced this?
Re: Only see input 1/2 from UCXII in Logic Pro for iPad
Not sure if this helps, in GarageBand on my iPhone it has an advanced settings enable multichannel recording.
Check if Logic in iPad also has a similar setting for enabling multichannel inputs.
Because you did not enable "Multichannel" in the Preferences/Settings in the TotalMix FX App on your iPad?
Check this in "RME Interface Settings".
“Do It For Her”
