Topic: UCX II as a reverb or delay effects pedal
Hi, I have an effects send and return on my guitar amp. The amp doesn't have any built in reverb so I was wondering if it would be possible to use my UCX II like a reverb or delay effects pedal? If so, how do I set this up? Thanks.
2 (edited by waedi 2024-10-17 09:18:17)
Re: UCX II as a reverb or delay effects pedal
From user manual page 100 :
TotalMix FX can transfer all current settings to the device (Options/Store Current State into De-
vice). There are six memory slots (Setups) available.
That means, you have to connect the unit to the computer and to the guitar amp analog in and analog out and in Totalmix configure the routing including the effects until it sounds good, then store it into the interface and after that you can use it in standalone-mode.
But if you allow me to criticize, better look out for a used guitar effect floor board
Something like this, add some delay with the foot pedal when you really want it.
https://thumbs.static-thomann.de/thumb/padthumb600x600/pics/bdb/_45/458546/13919816_800.jpg
3 (edited by ramses 2024-10-17 10:52:13)
It should be possible.
Consider using your UCX II / this setup to
- integrate high-quality external effects, like the Lexicon PCM
- build a parallel effect loop for the amp which keeps the punch/dynamic of an amp and adding FX 100% wet in parallel
You just need to:
    Connect the "Effect send" (preamp signal) to a hardware input, and
    Connect the "Effect return" (power amp) to a hardware output on the UCX II.
Next, connect your external FX unit to the UCX II.
Note: Some units, like the Lexicon PCM81 or PCM91, are stereo, so you'll need to connect both channels.
Finally, route the preamp signal of your amp:
    Directly to the power amp to preserve the punch and dynamics.
    To the external FX, adding the 100% wet signal to the power amp.
This setup provides excellent results.
Additionally, you can use Direct USB recording for backup, capturing the backing track from your PC along with recordings from the amp's mic or line out, depending on your preference.
If you connect your guitar to an instrument input on the UCX II, you can also record the dry guitar signal for reamping later. This allows you to adjust distortion, reverb, or other effects if needed. Simply route the guitar signal back through the amp using another line output from the UCX II.
I've been using a similar setup for home recording for several years with great success.
If the guitar is connected to the UCX II anyway in such a setup you can also make good use of VSTi.
All you need to do is to switch to another TM FX snapshot.
I have several TM FX snapshots for these use cases
   SNAP1 -  "Monitors" to playback sound from the PC on the Main Monitors (Main Out)
   SNAP2 - "HiFi" same for sending the audio signal to the HiFi (Main Out B)
   SNAP3 - "PCM81 -14" for recording the amps and adding external FX (PCM81) with mixer set to -14
   SNAP4 - "PCM81 -18" same as before but 4 dB less FX intensity
   SNAP5 - "PCM91 -13" same as before but with PCM91 and a little bit more FX intensity for the reverb unit
   SNAP6 - "Reamping" - routing for reamping purposes
   SNAP7 - "PCM4DAW" - routing to use both FX units (PCM81, PCM91) for the DAW for mixing and mastering
   SNAP8 - "SGear3" - enable playing through VSTi. which has a Plexi setup with great sound
Check out these blog articles showing how my setup has evolved over time. You'll find pictures of two combo amps and external FX in a stereo setup, mic’d with 2x2 mics (tube and SM57):
https://www.tonstudio-forum.de/blog/ent … iii-en-de/
This post covers my previous analog setup and the transition to an RME-based system, initially using the more affordable Lexicon MX200 as an external mono effect:
https://www.tonstudio-forum.de/blog/Ent … -DURec-DE/
This is what it looks like in action. Immediately ready for operation because all relevant routing and level settings - including those of the external preamps - are stored in the TM FX Snapshot
https://www.tonstudio-forum.de/attachment/3217-14-tm-fx-1-97-auxdevice-durec-pcm81-as-ext-fx-jpg/
BR Ramses - UFX III, ADI-2 Pro FS R BE, M-1620 Pro D, 12Mic, XTC, RayDAT, Win10, X10SRi-F, E5-1680v4
Hello
How goes it? ... If you need help to do it in stand-alone operation (without computer/TotalMix) please comment :-)
UCX II FW106/34/104 v1.271 TM1.99 - PC Win11 24H2 / Ubuntu24.04.2 - Reaper 7.41
5 (edited by ramses 2024-10-19 01:07:50)
@halloweenman:
Still no solution?
Send an input signal to "FX send" [ add some FX in TM FX ] and then you add it to the proper output by using FX return.
