1
Topic: UFX suddenly not powering on
I have a UFX that I have owned for just over 10 years and has always worked flawlessly. Suddenly it is no longer powering on. When I turn on the power switch I hear a buzzing sound coming from the interface and the LEDs in the STATE section flash very quickly. I have opened it to look if there are capacitors that have exploded but I don't see any that look fishy.
Does anyone have any idea what could be causing this? I have attached an image of the power section of the interface.
Thanks a lot for your time smile
https://photos.app.goo.gl/8oSCdJ1LWrksZVtZ9
https://photos.app.goo.gl/LKvwi5TQc35crACj6
Re: UFX suddenly not powering on
You may need to send the unit in to replace the power supply. Or order one through the local distributor if you can have it replaced locally.
Ok I will try to find one. Thank you so much for your response!
