Topic: ARC USB Setting Control Question
I have the ARC USB + Fireface UCX II.
Is there any way that the +13dbu/+19dbu setting can be changed via button assignment on the ARC USB?
Use case is that I have several guitars with varying degrees of pickup output, with a couple that have particularly hot pickups that forces me to toggle to the +19dbu setting to tame it. It would be convenient if the switching can be done via ARC USB.
