Topic: Room EQ Wizard and mixing
Hello!
I have HS8 and I've created impluse response for each speaker with REW. After that I placed the IR in MConvolutionEZ on the master. So I mixed on of my song with the corrected room. After that I found that my mix sounds harsh. It's like lack of equal-loudness curve compensation. And simple cutting harshness with an EQ on master doesn't help.
By the way not long ago I tried Sonarworks Measurement. I also tried to correct my room with it. And the result in mix was the same: too harsh on about 2-5k.
Is there anyone who faced a similar problem? Is ther any solution? May be I don't something important about room correction
