1 (edited by ultracello 2024-11-18 20:02:21)
Topic: Loopy Pro on iPhone: full access to Babyface Pro FS
There is no TotalMix app for iPhone. sad
Is there any chance to give the dev of Loopy Pro ability to get full access to the Babyface Pro FS parameters and also matrix? Loopy Pro on iPhone/iPad is able to send MIDI / OSC.
Babyface Pro FS, Fireface UCX
MacBook Air M1 / iPad Pro 12,9" M2 2023 / iPhone 15 Pro Max
Re: Loopy Pro on iPhone: full access to Babyface Pro FS
Would I think would be most useful is to add external midi control for the Babyface Pro FS regardless if it is using Totalmix or not. All the same parameters available in Totalmix would be best.
For context some use cases would look this.
A: Automation of parameters from a host DAW
B: Custom control surfaces made with Loopy Pro to control the interface
C: External control of the interface via physical midi controllers.
Is this on the roadmap?
3
1. Other than providing a MIDI I/O port to iOS, MIDI/OSC is not supported in CC mode for anything else.
2. General external MIDI control is not possible due to limited resources within the unit. It was simply not developed to do that.
