Topic: Fireface UC - HW inputs phase switch not working?
I recently purchased a set of polarized microphones which - by design - invert the phase of the input signal ('a positive pressure on the diaphragm generates a negative output voltage.')
My assumption was that I would be able to 'invert back' the mic signals (converted to line-level type through a specific external signal conditioner) at RME Fireface inputs by using the Phase button available for the various HW inputs ch. strips in TotalMix.
Running some measurements I realized that the Phase switch in HW inputs has no impact on the acquired signal. The only control in Settings that seems to have an effect is Gain.
On the other hand, Phase switches in SW playback & HW outputs sections do invert the signal, as expected.
I could not find any explicit reference as to why such function should not work for the HW inputs as well.
Am I missing something here?
Thanks in advance for your support!
