Topic: Transfer Headphone EQ from Pro Q 3
Hi, I used to use Fabfilter Pro Q 3 on the output of my DAW to correct the frequency response of my headphones.
Now I've bought an RME Fireface UCX II and I would like to transfer the curve to the RoomEQ of the headphone output in TotalMix FX. Can I copy the parameters as is? Are the Q values the same or do I have to convert it in some way?
Re: Transfer Headphone EQ from Pro Q 3
if you would figure out how to create an impulse response via this ProQ then you can import the IR into REW and export the room-eq file. somehow. Until then I would use the EQ numbers one to one.
Thank you. Any idea about how to create an impulse response of the Pro-Q 3 profile?
https://youtu.be/pGEEpWPGIYI
Thank you
