Topic: Fireface 800 - Latency issue on one channel
Hi all,
I am currently dealing with small but noticeable latency on one source input in my current system. Its minor but is causing phase coherence issues.
My system is centred around an Akai MPC Live 2 which is patched over analogue I/O (6x line level outputs TRS) to the rear line inputs of the FF800. The MPC has been calibrated to match dBu levels with the FF800.
I recently purchased and installed a Moog Moogerfooger MF-101 analogue filter for external processing, the unit is patched from output 6 of the MPC, and then patched into input 10 of the front mic/line inputs. I needed extra input level from the MF-101 to match dBu between systems, hence the front mic/line inputs.
When I first tested the MF-101 incorporated with both the MPC & FF800 I instantly noticed an issue with phase coherence when all MPC outputs were summed and open, however the unit sounds fantastic when isolated. So I’ve created a latency test with both the MPC and a Pro Tools session. I’ve programmed and sequenced a click track to output simultaneously on both output 5 & 6, out 5 is MPC is direct output and out 6 passes through the MF-101 (hard patched). Sure enough the MF-101 has latency offset against the direct MPC output of 0.0227 milliseconds. Small but enough that it it's noticeable.
So I’m curious if this is typical due to signal passing through an analogue signal processor like the MF-101 (resistors, capacitors, transformers), or is the front mic/line inputs utilising a different AD/DA or processing path than the rear line inputs. I’m monitoring all system inputs via Totalmix and I don’t believe you can manually adjust latency offset per input. This won’t be an issue during mixdown in Pro Tools as I can manually adjust the offset track’s position, but since I’m monitoring the MPC composition stage via Totalmix I’m stuck with this phase coherence issue.
Any suggestions or advice? Would the rear line inputs resolve the latency issue or would it not make a difference?
Thanks for the read.
