Topic: Db25 question
Hi everyone. I have ordered to make db25/8 trs cable to connect my drum module (pearl mimic pro) with ufx3. Guy asked me in which pinout system it must be done. I cant find it in module manual. Can You help me?
2 (edited by waedi 2024-12-09 16:01:57)
Re: Db25 question
the user manual indeed does not say any word about special pinout, therefore it should be(has to) be regular Tascam norm cable.
https://www.thomann.de/de/cae_subd_25polstkl_3m.htm
Re: Db25 question
Thank You. I cant send it back because its not regular order. Its one way bill:)
Re: Db25 question
You already have a cable ? Your post was different.
Is the cable not working ?
Re: Db25 question
You will need to ask Pearl... It's just individual TRS inputs on the UFX, no pinout required.
6 (edited by sinolonis 2024-12-09 20:17:54)
Re: Db25 question
No I have ordered one. They are making it and asking for pinout system. Tascam or yamaha. I hope its standard tascam. Im still waiting for response on pearl mimic pro group on fb. I need to tell them soon because I need it quick
7 (edited by waedi 2024-12-09 21:49:12)
Re: Db25 question
You could bring the MimicPro to the cable maker, he could beep the ground pins and compare to the tascam layout. The Yamaha pinout is very different. Or do the beep test self and let him know.
https://i.ibb.co/zJdxYVP/Bildschirmfoto-2024-12-09-um-20-45-11.png
https://i.ibb.co/jy4Wqj2/Bildschirmfoto-2024-12-09-um-21-44-11.png
Re: Db25 question
It is tascam. Thank You guys so much:)
9
Re: Db25 question
Indeed - they completely forgot to give the pinout information. Not on the website, not in the manual. BTW, if it is Tascam, then this is also referred to as 'AES 59'. The 'Tascam standard' became a real standard in 2012 already, mostly unnoticed from the public (even me).
