Topic: Adi-2 Room EQ with fireface 800
I own the ff800 considering that software updates won’t be there for much longer I was thinking to either upgrade to the ufx 3 or take the aid-2 black edition and used it in connection with ff800 so to connect my 5.1 set up. I was also hoping to make use of the room eq feature which came with latest total mix fx on the other channels. My thought process is, have the adi-2 connected to my MacBook Pro as my main interface, connect the ff800 using optical cable to extend the I/O’s. But I am not sure if I would be able to use room eq on those extended outputs. From my understanding it should work as up 20 output channels can be used simultaneously and the total mix fx would be working over the adi-2. Anyone insights from the more seasoned community members here?
