Topic: cannot launch digicheck5 or 4.53
using
HDSP AES32 with driver 3.07.3
Hardware rev 233
Windows XP Pro SP2
Intel Core2 6300 @ 1.86GHz
2.00GB RAM
previously using Digicheck 4.44 with hardware rev 231 and driver 2.52, no problems.
Installed drivers 3.07.3
Flashed the firmware to v 233.
Installed digicheck 5.
On first run, program asks me to select a folder to record to - I click OK and no file requester widow opens, no interface at all visible, but task manager shows digicheck process is running.
Installed digicheck 4.53.
same result as above.
Installed digicheck 4.44 (the version we previously used).
This version cannot find any compatible hardware, but the interface opens.
Note: the audio device itself is recognised and works fine with the DAW software.
does anyone have any ideas?
thanks,
ottor
