Topic: madi total mix help required - again
i am trying to do some more complex, (complex for me that is) routing with totalmix, by creating some send effect paths. I am having difficulty because it appears that all input channels are routed to the corresponding output channel. I cant stop it.
Here is my scenario:
playback stereo 1/2 is routed to output 1/2 (monitors) and also to output 49/50, which is a reverb effect send.
the 49/50 travel out to some nice verb effects then find there way back into the madi card input on 57/58 with the magic of the adi648.
Now output 57/58 is another effect send, digidelay, and the input 57/58 appears to by default get routed out the same channel that it comes in on. My lovely piano with reverb on it then gets routed down this path.
Is all i have to do reduce the gain to -inf on the input channel 57/58 to stop it being sent back out to the second effect send? is it as easy as that?
totalmix with adat/madi is an octet nightmare
kind regards to all RME fans!
may all your recordings be in 192khz with the micstasy
