Topic: Audio stuttering randomly with Multiface II+PCMCIA Cardbus
I experience a severe problem for a while now and I have been unable to find a cure.
This is the case:
I create a new project in Cubase 4, load a VSTi, record some midi, and in random times audio starts stuttering playing the last buffer for 2-3 seconds.
This does not happen in heavy projects but in newly created and light as well.
My system is optimized for audio recording. Here are my specs:
Toshiba Laptop Satelite
Intel Core2Duo T7400 2.16Ghz
4Gigs of RAM
7200SATA hard drive
RME Multiface II latest drivers 3.075
PCMCIA Cardbus flash updated
PCMCIA Controller on laptop:Texas Instruments
Frontier Design Alpha Track
Novation Nocturn
Windows XP 32
I have already tried the DPC Latency Checker tool and when the stuttering occurred there is no overhead at all. I have even made a video showing this if this helps. Internal soundcard is disabled.
Also I would like to note that Cubase 4.5.2 does not show any CPU overhead when the stuttering is happening. Moreover, after the 2-3 seconds that the stuttering lasts, everything gets back to normal and I may continue working for a while before another audio buffer stuttering occurs.
This is one of the most difficult things to solve that I have encountered so far. There is no error, no log file, it happens unexpectedly, everything seems normal (even DPC shows normal behavior) and everything returns to normal after the problem has occurred.
I am almost going out of my mind with this one.
Any help would be more than welcome. Thank you in advance.
