Topic: High Frequency Loss in one channel....
I've written to Matthias about this a couple of times and he has had no ideas (yet). I'm sure we'll figure it out some time.
This is the third time that this problem has occurred and it is worrisome because the engineer does not always notice it since it is occurring in one channel. It happened again yesterday and I set out to document it as carefully as possible. We'll get to the symptom in a moment:
I have FOUR MADI to AES interfaces (ADI-642). They're all configured for AUTO delay compensation and AUTO input/output assignment. The computer is a MacPro running Bootcamp and Windows XP Pro.
I've only confirmed the problem in the first interface, I do not know if the rest of the interfaces have the problem when it occurs. This is the interface that says "AUTO01". This one I use primarily for monitoring and I can feed any of the four AES outputs to a stereo DAC via a Z-Systems AES router. The sample rate is 96 kHz and all the interfaces are locked to a 96 kHz wordclock. Frame is 48K, 64 channel format. The ADI-642's are configured so that they automatically go to double sample rate when they detect a 96 kHz wordclock. I did NOT test the other three interfaces when this problem happened.
The high frequency loss problem that occured Wednesday happened AFTER I shut down the computer and then turned it back on, without powering the interfaces down. In other words, the interfaces stayed powered on and continued to receive 96 kHz wordclock from my A/D converter even though the computer was shut off.
The first 8 MADI outputs are assigned to the first box's four AES outputs. I use a pink noise signal for the test so the conclusion is unambiguous.
AES Output 1&2, output #2 has high frequency loss. (all these are severe losses, I did not measure it. Next time it happens I'll measure the loss).
AES Output 3&4, output #4 has high frequency loss.
AES Output 5&6, output #6 has high frequency loss.
AES Output 7&8 is fine (no loss). Interesting, eh?
Rerouting or exchanging DAW (software) channels via Totalmix shows that Totalmix is not the cause but isolates the problem either to MADI output channels 2, 4, 6 OR to the even numbered channels of the first interface.
I tried all kinds of resetting in the first interface, changing from ADC on to ADC off, 64 Channel to 56, 48 frame, etc. etc. etc., and the problem remained. Then I power cycled the first interface only and the problem remained. Then I turned off the power for all four interfaces and turned them on sequentially, waiting for the first interface to settle down, then powered on the second, and so on. Then the problem went away.
This implies that the first interface is improperly synchronized and is confusing the rest of the interfaces as well. Some MADI synchronization problem in the bitstream happened which confused or partially locked up one or more of the interfaces. And since I had to power down ALL FOUR interfaces to fix the problem, it's probably not caused by one interface per se, but by the powering up of the computer confusing the interfaces. It looks like every time I power up my computer I should first power down the interfaces.... However, this problem has occurred in the past without power cycling the computer.
I hope this helps you come up with ideas. Thanks,
Bob
Bob Katz 407-831-0233 DIGITAL DOMAIN | "There are two kinds of fools,
Recording, Mastering, Manufacturing | One says-this is old and therefore good.
Informative **CD MASTERING WEBSITE** | The other says-this is new and therefore
http://www.digido.com | better."
No trees were killed in the sending of this message. However a large number
of electrons were terribly inconvenienced.
