Topic: MADI and AES no god mix.
Hi
Finnaly a forum for us rme fans!
But its not all well in the rme world.
After struggling for month wid mysterious clicks and popps, unstabillity and WERY high buffer settings, it all came down to that the following sentence is not correct!
"Up to 3 HDSP MADI and HDSP AES-32 can be used simultaneously. With this up to 192 inputs and 192 outputs are available at 48 kHz, 96 inputs and 96 outputs at 96 kHz".
There is a weird sync begavor when using one MADI and one AES-32 card, it simply not working. Audio sync suddenly dissapear on the AES card, there are clicks, unstability. Sometimes it works for an houer or so, but then suddenly....no sync.....and this no matter how much free prossesor power you have.
As far as I know rme has rekognised this as a bugg.
Stay away from mixing MADI and AES on the same machine until rme confirm that this is adressed.
