Topic: Multiface II, Linux and 8 analog channels @ 96 kHz
I have got reports about problems with using 8 channels @ 96 kHz with Multiface II in combination with Linux.
The output channels are prep'd by ALSA amixer commands:
amixer -c 0 cset numid=5 26,0,32768
amixer -c 0 cset numid=5 27,1,32768
amixer -c 0 cset numid=5 28,2,32768
amixer -c 0 cset numid=5 29,3,32768
amixer -c 0 cset numid=5 30,4,32768
amixer -c 0 cset numid=5 31,5,32768
amixer -c 0 cset numid=5 32,6,32768
amixer -c 0 cset numid=5 33,7,32768
The first four channels are working but not the other 4 channels.
Does someone know a reason for this problem? According to the manual the 8 analog channels should all work with 96 kHz samplerate.
An ALSA driver problem or a problem of correct adressing?
Thanks for any tip
Uli
