Topic: Channel Numbering when changing Sampling Rate
Hi all.
I have a MADI setup with:
2x MICSTASY, 1x ADI-642, 1x MADIFace + Sequoia (MBP/XPSP3)
When I record at 48kHz everything behaves as you would expect -16 channels of 48kHz Audio gets dumped to disk.
When I record at 96kHz, Channel 1 from MICSTASY ID1 appears as channel 5 in Sequoia. The last channel from MICSTASY ID2 appears as channel 20.
I'm not _very_ experienced with MADI (this is my first rig) but I am getting the hang of it fairly quickly.
But, this channel numbering thing is a little confusing.
I am also not convinced that the 'follow clock' is working properly on the ADI642.
When I select it on the MIDI Remote, it stays lit for a couple of seconds and then goes out again.
FC seems to be OK on the MICSTASY's.
Madiface firmware is 15 (latest?)
Also, latest Windows drivers
MICSTASY firmware is 2.1
any pointers would be greatly appreciated.
thx.
Mark.
