Topic: HDSP9632+HDSP9652+4x Behringer ada8000: word clock sync?
Hi
I hope nobody will bash me for my (cheap) choice of converters. I have the two cards synced with the internal connection, and additionally to the behringers also a TC D-two via spdif (9632). The B's are synced 'just' through the adat connection (one of the RME's is the master). Actually, all works very well & stable.
However, reading that clocking can have an impact on the audio quality, especially with several external devices, I wondered if I could improve the setup by syncing the behringers with word clock (since the 9652 has Word Clock out). One issue I see is that the B's do not feature a 'termination' switch.
Since I have a pair of behringers on each end of the studio, I would like to have a 'T-Connector' on the 9652 out, to get two strings out (one to each pair of the behringers, which then would be daisy-chained again with a t-conector).
Does that make sense? Has anybody experience in syncing more than one of these? Is it worth it or should I just keep trusting the highly stable 'adat-syncing' of the RME's as masters?
Many thanks for any reply.
Regards flo
