Topic: ADI-8 QS toggle analog inputs
I am wondering if it is possible to toggle between the DB25 and TRS analog inputs.  As I understand it only one set can be active at a time, but I am wondering if it is possible to control which connectors (DB25 or TRS) are active from a desktop control panel without having to swap cables.  I would like to be able to keep my 8-channel mic pre connected via the DB25 and connect auxiliary studio equipment to the TRS inputs.  Any ideas?
Most of this rig is mobile which is why I have not adopted the use of a patch bay for this particular setup, FYI.
Thanks in advance,
Eric
Re: ADI-8 QS toggle analog inputs
The inputs are hardwired=connected within the unit. So any solution must be outside.
