Topic: TotalMix skins install help
Hi guys
I have a fireface 400 and i would like some help with skins install. i go to Path XP: Documents and Settings\Username\Local Settings\Application Data\RME TotalMix but all i find is a (default1.fmx
) file not any .bmp to replace... Could anybody tell how to do it step by step...
Thanks in advanced,
George
Re: TotalMix skins install help
I have the same Problem with the new Fireface 800 Driver.
Gretings Bernd!
It?s described here. You have to create a bmp folder in the RME TotalMix directory.
best regards
Knut
The "bmp" folder does not exist, you have to create it. Then the driver will load the files placed inside on next start.
The "bmp" folder does not exist,......
But it was not a Problem in the Past?
I don't understand?
If the folder does not exist, the regular skin is loaded. If the folder exists, the bitmaps inside are loaded.
7 (edited by bs75 2010-01-12 01:34:45)
Sorry, it was my mistake, I have looked at a wrong place.
Greeting Bernd
http://www.abload.de/img/totalall4p6e.png
