Topic: Some questions about Level Meters
Hi!
I am using DC's level meters to analyse the levels of some files, after noticing the Ovr indication in the Totalmixer.
It's a great tool, especially when using the OVS mode, thank you very much for it!
Now, my questions:
1) In the level meter setup dialog, when I try to change the Top Level, it indicates that the valid values are -80 ... 20dB, while in the help it says that the valid values are -80 ... 0dB, and, in reality, the valid values are -80 ... 3dB. Which of them is correct?
2) The Warning Level is when the color changes from yellow to red, but this only happens bellow 0.0dB. When the meter is >= 0.0dB the color is alway white. I believe that 0.0dB is still a good value, that only 0.1dB is really overloading, but since it's always white for >= 0.0dB we cannot watch it correctly.
I'm using DC 5.23 and have a FF400.
Best Regards.
