Topic: Locking mixer and settings: Improvements requested
we appreciate very much the features which enable us to lock the mixer and to lock the driver settings ("lock registry"). Thanks a lot!
We still would like to ask for some improvements:
- When entering the password it is always shown as clear text at the moment - hmmm...
- When more than one card ("unit") is used and mixer locking is active, it is impossible to switch units in TotalMix: only one unit is viewable, which applies to the matrix, too. That's a real drawback: Even if we want to prevent users from changing mixer settings we still want to be able to view the active settings.
Is "lock mixer" a global parameter or does it relate to only one unit? Once I ran into a situation when I unlocked unit 1, accessed unit 2 and this one had to be unlocked as well!
Is it possible to invent a switch for unit views also for the matrix? Maybe in the system menu of the matrix window?
Best wishes from Cologne,
Ulrich
Re: Locking mixer and settings: Improvements requested
One more:
With the current implementation (3.08.2) it is not possible to prevent a "user" from making himself an "admin": Leaving the settings unlocked (which of course may be desired in certain situations even in a broadcast environment) enables everybody to lock them! And how can we delete a password in case it's lost? Any solutions beside a new driver install?
Ulrich
it still would be interesting to know RME's attitude towards these issues.
Ulrich
The PW can be found and deleted in the registry (not sure of the exact path right now, if you look for RME, you'll find it).
