Topic: What happens when using AES in when Micstasy is running MADI?
Hi!
We've got a system set up that uses three Micstasys for 24ch over coaxial MADI into a HDSPE card. I just started wondering, what happens when you send signal into either of the units AES/EBU inputs?
Does the AES signal get inserted after that Micstasys channels unto the MADI network?
Re: What happens when using AES in when Micstasy is running MADI?
As mentioned in the manual the AES input is for clocking only.
Thanks, that's too bad. Would have been useful to be able to use the inputs...
