Topic: Question about Digicheck Global Record
Hi all,
I'm having a slight issue regarding the Global Record function. Here is my current Digicheck setup:
After I record essentially a "What-You-Hear", I save the recorded data as Two-Channel files (A Stereo WAV). However, everytime I render the recorded data, Digicheck keeps creating a separate WAV file which is essentially complete silence in addition to the proper WAV mixdown.
Is there something wrong with my Digicheck Global Record setup that is causing this extra file to be created? Thanks for any advice!
