1 (edited by themarqueeyears 2010-01-01 11:27:45)
Topic: Correct SP/DIF Preferences when using Multiface with professional AES
I have read the Multiface manual and feel fairly happy I'm corrct in my thinking, but I need to be sure as it's for a really important project.
I am connecting my Multiface to a Z Systems Digital Detangler wich is professional XLR AES format.
I have followed the manual and made up the correct unbalanced to balanced coax sp/dif to XLR AES leads.
From my reading the manual I so far understand that the Multiface is perfectly happy recieving full voltage professional AES signal.
My question is:
I am ticking the ?Professional? format option with doubled output voltage in the SP/DIF out section of DSP menu.
I need to confirm this is correct, it appears that the Multiface can recieve professional AES without needing to do anything and to transmit professional AES I need to tick the "professional" box in the SP/DIF out preferences menu.
Hope someone can confirm my thinking is correct.
TheMarqueeYears
Re: Correct SP/DIF Preferences when using Multiface with professional AES
All correct.
All correct.
Great, that's what I wanted to hear.
Thank you for taking the time to reply, I appreciate it.
Best
TMY
