Topic: hdsp9632: Anyone have a problem with negative delay?
For the last few years I've been using the workaround of delaying all my midi tracks within Cubase because otherwise midi info sent out the 9632 will be in advance of the audio by a factor of at least 100ms. It might vary according to overall latency, though I rarely change this - I could do some teasts if that would help.
Recently I switched to Logic (I use a Mac) and instead of just using the same workaround, figured I'd see if anybody knew a simple fix.
Does that ring a bell?
Otherwise, the midi timing is pretty good - it's just too early, unless I delay it.
My system:
G5 1x1.8GHz
10.4.11
hdsp9632
UAD-1
thanks!
Matthew
Babyface, Macbook Pro 2015, OSX 10.14.6
Re: hdsp9632: Anyone have a problem with negative delay?
El bumpo!
Nobody out there having this problem?
Last-ditch bump!
