Topic: double click on rotary encoder doesnt work
hello,
when my device is not connected to any computer, i try double clicking the rotary encoder to switch operating modes, but nothing happens when i double click.
i've tried several times, clicking at super-human speed. nothing happens.
any suggestions?
thanks
Re: double click on rotary encoder doesnt work
Maybe you can try to re-flash with the last firmware ?
no need to reflash! probably its a problem mit the pot - the problem is that the encoder sometimes goes "to deep" on the stick of the pot smile sounds funny but i am serious. solution is: just PULL the pot a little bit outside on the stick of the encoder, then double-press will work again ... untill it "falls back" on the stick. then redo the process. if u want a permanent solution dismount the pot and put some glue into the hole, then put it back (but not too deep...)
i know sounds crazy, but try it out smile
cheerio
