Yeah, sorry i was in a hurry when i posted the question.
Yes, -89.5db
This is the main mix (L & R) from the desk into my converter (Lynx Aurora) via a RayDAT. The converter is set to +4. If i drop it to -10 i still get too good readings in Digicheck. The signal is unbalanced but +4 level. I have the master faders @ unity (top of their travel). And i monitor the inputs in Totalyzer. On an ordinary level meter it should be about -55db mix bus noise (not very good) for this console. I would like to get the correct numbers before i start refurbishing the desk; i'd like to see how much difference there are after a good refurbishment.
These numbers are clearly not right as i can hear the noise and some hum. If i plug in a mini mixer i get like -107db on the mix bus, which i've never seen in any mixing desks specifications. It usually (for a decent and mid size desk) is about -75db mix bus noise.
So how can i measure signal-to-noise in Digicheck and get specifiactions that i can use when i compare my gear to specifications in manuals etc? Or, how do i convert specifications in manuals so they compare to readings in Digicheck? :-)
Thanks!
