Topic: "Old" FF800 + TCO
I have FF800 for few years and still using FUT 2.47 as I have read that old units need "small hardware modification" to work with higher Firmware. Now I am going to buy TCO. Should I make that "small modification" first or will it work with TCO and FUT2.70?
RobR
Re: "Old" FF800 + TCO
where have you read that info, I have a FF800 from aug 2004
and no trouble to run latest drivers/fut on both PC & Mac
or does it mean small hardware modification with old FF800 to be able to run TCO at all !?
just asking
regards S-EH
I have bought mine in september 2005 (SN: 22456091)
I have had problem with one of FUT higher than 2.47 (do not remember exact number) and since then I do not update it according to what RME says:
"Revision 2.70 is only required when a TCO is used  with the Fireface 800. Else please use revision 2.47."
Here one can read about that secret "small modification":
http://www.rme-audio.de/forum/viewtopic.php?id=6954
regards,
RobR
Robr, Thanks !
regards S-EH
