Topic: Possible to make appropriate -6dB input pads for the ADI-8 Pro?
This is likely an easy question for some of you, but I'd like to know what value resistors would be advisable for making a -6dB "H-Pad" (or whatever type pad would be appropriate here) that would be appropriate for padding the ADI-8 Pro's inputs. I've tried using the H-Pad calculators available all over the web, but the resistor values get all crazy with smaller attenuation levels like -6dB, and I'm not exactly sure where to begin with the target impedances.
The Preamps to be padded are a slew of Seventh Circle Discrete modules that can output +25dBu and beyond IIRC (I think the N72 is +27dBu and 30v p-p), and are mostly transformer coupled outputs. I want to get more transformer saturation and gain-stage color when desired w/o clipping the ADI-8's inputs. IIRC, the Seventh Circle pres are happy with a load impedance of 600 Ohms or greater (the modules have internal 600 Ohm Jumpers for connecting to higher impedance inputs). I'd prefer not to go too far beyond -6dB to -8dB as then I will run into clipping well before I hit 0dBfs (I tend to track with conservative levels regardless).
I have a bunch of -14dB Mic pads (using 470 Ohm on each leg and a 220 Ohm across them as mentioned by a Neumann developer), but these are too drastic for a Line Pad (to much attenuation - can't get above -6dBfs w/o hard clipping), and I believe the impedance is not ideal for a line output involving a transformer.
I've seen that Little Labs offers the Attenuator 8-Pack, but it is very expensive, I'd need 2 of them, and I already have a bunch of empty Neutrik XLR barrels to make these pads from if the appropriate attenuation values and impedances can be obtained with such a pad...
Thanks for any help on this seemingly simple (but somewhat harder in practice) conundrum. I have indeed done much research sprinkled among many years, but most online pad talk seems to be aimed at Mic applications, and don't seem offer the smaller attenuations that I'm after (if even possible).
Sorry to be so wordy (some might say "Thorough" fryingpan ). You guys rock!!!
2x SSL Alphalink MADI AX
