Topic: Output problems
Hello
I have some troubles making sound out of Out 3+4 on my RME fireface UC 400, out 1+2 is routet to a pair of active speakers and i wanna route 3+4 to a normal intergrated amp for a second listen setup.
My sound is iMAC via USB and i "think" i have been trough everything, but i will just not accept "No sound" it seems like no problem if it is with another source let's say in 7+8 wich is a drum machine, then the sound runs fine. Could it be that it is because usb can only run to Out 1+2?? i have try other out with no luck:-)
By the way...this soundcard sounds amazing:-)..!!
Hope for some help
Best regards
Kristian
Denmark
