Topic: Digital anomolies
Hi all
I have been mixing in the box using the analog out of of asio 1/2. I just picked up a folcrom 16 channel passive summing box and went to use the other outs and I get this weird high pitched ringing on top of the recorded signal on all analog outputs from
asio channels 3/4-5/6 and 7 channel 8 works fine. I am clocking the unit using a lucid gen x 6/96 The adat outputs are working fine and I have tried every configuration I can think of  internal clock external clock etc. etc. any help anyone can offer would be greatly appreciated.
Re: Digital anomolies
Hi, never heard of such a problem before. Did you check the outputs directly - without using the summing box?
