Topic: Win 7 firmware upgrade notes for HDSP 9652
Just a note for anyone searching here in the future on this issue. I was completely unable to do a firmware upgrade on the HDSP 9652 under Win 7 Professional 64-bit until I put UAC in the completely off position. With UAC turned on but in the lowest of the 4 positions the upgrade software didn't do anything including even pop up a window to tell me it was having problems.
Once I turned UAC off the upgrade proceeded fine and when completed I was able to put it one level up. (where I am currently running it) The HDSP 9652 seems to be working fine.
I hope that RME Will support the Alsa developers with info on the firmware changes as this has broken my compatibility with Linux.
Cheers,
Mark
Re: Win 7 firmware upgrade notes for HDSP 9652
Did you try giving the firmware upgrade software administrative rights when you launched it? That's: right-click and select "Run as administrator". Usually that bypasses the W7 UAC security.
MBP = HDSPe Expresscard: MF1
