Topic: using two fire face 800 together help!
i can get only one setting box to show up? and one mixer .very new at this please help thanks mike
Re: using two fire face 800 together help!
The Settings should allow you to choose which unit you control (either a tab or a drop down selector, depending on your OS), the Mixer has buttons on the right side to select which unit you control (CTRL + click on the unit button to open a separate mixer window).
i still only have 1 fireface in the fireface setting box should their be 2
