Topic: MADIFace problem Mac Book Pro & Windows 7
Guys
Have recently upgraded Bootcamp partition to Win 7-32bit / Bootcamp 3.1
Installation of the MADIFace drivers appears problematic.
Driver appears to install, but hardware remains non-functional with Warning (Yellow) icon in the device manager.
Attempts to "update" drivers fail as the OS can't find a better version of the driver. (using 3083 build).
"Resources" tab indicates that the OS can't find enough resources for the card to function and that I should go and disable some other devices. Easier said than done on an MBP!
Attempts to uninstall the driver result in a BSOD.
MADIFace works fine on same hardware under MAC OS X
Has anyone had the same experience here and if so, is there a workaround.
Thanks,
Mark.
