Topic: RayDAT slaving at 44099Hz??
running two HDSP(e) RayDAT cards (3.08.2, v11) in two different machines, one refuses to slave to WC at the correct rate, dropping 1Hz.
This means I have to run it as a master, which does not suit my needs as I want to sync both cards to a single external WC source.
I have tried everything, but I keep getting this 44099Hz if the card is in slave mode.
What explanation if any is there for this?
Is the card faulty?
I seriously want to avoid the hassle of swapping the cards over to check if it is indeed a malfunction.
Thanks.
Re: RayDAT slaving at 44099Hz??
'Slaved correctly' is not indicated by the coarse display of the sample rate, which is a guiding help and not an exact measurement tool, but by the display of SYNC only. In other words: your cards work perfectly.
OK, thanks for clarifying, I wasn't aware that it was only an approximation of the sample rate.
regards
d
