Topic: Windows detection problem
Since latest update of firmware & driver, I have detection problems in windows.
Reguraly during the day, I loose sound if there's no audio application running.
Several times per day, I loose sound on the pc:
- mixer & fireface settings are still available
- Windows displays the fireface controllers in the sound admin panel
But I can't click on the configuration button (the one that test every speaker).
It seems that every time I loose sound, I can't either click on the windows configuration button.
A power reset of the card is generally correcting the problem, but if I don't use any audio software, it will start again.
I work with:
Windows vista 64
Fireface 800
driver version: 2.9.992.0
Firmware version: 2.77
thanks
Re: Windows detection problem
Does the HOST LED turn on when this happens?
3 (edited by fletchernic 2010-04-29 08:54:59)
No, only the in / out level LEDs are always on.
