Topic: saving wavs: filename inconsistency?
during the last couple of weeks I recorded a series of concerts with my FF800 and GlobalRecord...
it worked great - as usual - but a small thing came to my attention: if you wanna use upper and lower case letters in filenames - as I often do - this doesn't work when saving right after recording, but it does work, if you reload a previously saved multichannel file...
e.g.:
+ record something and save it right away: if you choose the name "theFileNAmE" will result in wav(s) named "thefilename"
+ reload a previously recorded multichannel file and save it again - will result in "theFileNAmE", as expected...
strange, ha?
HeadScratch
best,
laex
