Topic: Driver Installaion Question.
Hi there
I am a happy MultifaceII owner and have just received a new DAW with Win7 64-bit installed. I will be using Sonar 8.5PE in 32-bit mode and usually use ASIO because I was unable to get WDM to work on my old system.
I am unsure of which driver I require and require clarification before I install.
Although my MulticfaceII uses a Firewire cable, is the unit categorized as being HDSP?
If so, is the driver below the one I should use from this page?
WDM streaming driver for the whole Hammerfall DSP Version 3.083, hdsp_wdm_3083.zip
System. WDM, WDM-KS, GSIF and ASIO for all HDSP 02/19/2010
and HDSPe cards.
Also, will I still require my MultifaceII's installaion CD to instal total mix, or is this included in the driver installation?
Thanks and kindest regards.
LiD
