Topic: How to use "Room EQ Wizard" analysis software with Fireface 800?
I would like to be able to "sweep my room" for frequency response and 3D waterfall curve displays so I can see how my bass traps and recent acoustical treatments are working (or not).  However, the software I would like to run, called REQ (Room EQ Wizard) is written under JAVA and will not support the ASIO drivers my Fireface 800 is using.
Does anyone know a way I can run my Fireface 800 under some sort of Windows WDM drivers temporarily to run the Room EQ Wizard program so I can simpy take a reading?  I really don't want to delete my present drivers and do a re-install just to run one application.  Thanks for any help...
Re: How to use "Room EQ Wizard" analysis software with Fireface 800?
The FF 800 drivers always supported WDM, so where is the problem?
I should have read the manual first. I take it I should have the box "Interleave" checked. I'm away on concert trip this weekend but when I get back I will take a closer look at that setting.
