Topic: MINI DIN Pinout Configuration
I Purchased a used RME-HDSP9652 and did not receive midi/ADAT SYNC/Spidf break-out cables. I would like to build one for the MIDI DIN Connector. What is the PINOUT configuration for the 9pin mini din to Midi connectors?
Re: MINI DIN Pinout Configuration
you can order the breakout from the nearest RME dealer/distributor. The pinout is in the manual, is it not? Else, I have it somewhere, would need to search a bit.
I Checked the manual and did not find it. I am want to build cable with male DIN connector to go into a device in my computer rack.
I got it thanks.
Thanks Jeff for the info.
I too, find myself in ta similar position to cybertronicstss in wanting to interface with my HDSPe AES32 card and run connections to a breakout panel. When I purchased my PCIe card (around 2006? - One of the very first available in Australia) no cable was included in the box so I don't have a cable to copy.
Would someone be kind enough to supply the pin-out of the 9 pin mini DIN MIDI breakout cable?
Thanks in advance.
Greg
RE: HDSP9652 - 9 pin Midi pinout
Hi All,
Does anyone have the actual pinout for the 9 pin mini din MIDI breakout cable? I've seen this question asked in many places, but never is the actual pinout shown anywhere :-/ ... Could somone please detail the pinout? Thanks in advance!
7
German saying: wer suchet der findet...
https://forum.rme-audio.de/viewtopic.ph … 41#p104541
Thanks for your prompt response Mattias.
Have a great day!
