Topic: Problems setting up HDSP 9652 PCI - help please
I recently installed my HDSP 9652 PCI Card on my Vista 64 bit system, updated drivers and firmware and everything seemed to go smoothly.
I need some advise as to how best set up the the card with the rest of my system...
I am running Nuendo 4.3 and have my stereo Main buss out set to spdif out on the HDSP 9652. I have connected the spdif breakout cable to the spdif in on my external converter (I am temporarly using Presonus firestudio 2626 as a stand alone converter unitl my SSL Alpha Link MADI AX arrives next week). From the firestudio 2626 I have routed the spdif Main Buss signal to Anologue outs 1 + 2 which to my main Control room monitors....This setup seems to work fine...
The problem i am having is getting signal into the HDSP 9652. Today I tried to set up the digital out of one of my preamps into the HDSP 9652 and couldn't get any signal...I took the adat out from the preamp to the adat 1 ins on the HDSP 9652 - I synced the pre amp to HDSP 9652 via BNC - the preamp indicated that the units were synced but no joy with the HDSP 9652 and no level in the RME total mix. I then tried using spdif out from preamp into the remaining spdif in on the HDSP 9652 and again no luck...
I have a feeling it is a sync issue or I'm missing something to do with total mix... The HDSP 9652 was set to master in both cases...
How should my settings be in the settings dialog that u click in the windows taskbar and how should I setup total mix
I hope i made some sence trying to explain my setup, if you need more details just ask...
hally
