Topic: HDSP AES-32 and Clocking
I'm clocking 4 units of digital gear in the following manner:
Crane Song HEDD (master clock) Word out --> Aurora 8 (Word In T-Bar connector) --> AES-32 (Word In-Word Out) --> Lexicon PCM92 (Word In and terminated).
In this setup I have tried using at T-Bar connector on the AES-32 (bypassing the Word Out) but the whole system goes out of sync if I do.
I've done a ton of research on clocking without a dedicated clock and using T-Bar connectors in a Word Out --> In --> In --> In (terminating the last device in the chain) is preferred over using the Word In/Out on each device in a clocking chain.
My question is why does this setup fail when using a T-Bar connector on the AES-32? The internal jumper is not set to terminate. Why does this work ONLY if I use the Word In and Word Out of the AES-32 card?
DB
