1
Topic: Madiface expresscard and Fireface800
Is it possible to use on one macbook pro both cards?
(Madiface and Fireface 800)
Best
JR
Re: Madiface expresscard and Fireface800
Complicated. You need to sync the MADIface and Fireface, which requires a third unit as the MF does not have any outputs fitting the FFs inputs. Also see this forum for most Macbooks not working with ExpressCards correctly.
Thanks Matthias,
I try to record on MacBook Pro 64 audio tracks in Logic 9 from Madiface.
So far it works.
What kind of trouble should I expect?
its important, I must record show in China in few days.
Thanks for any advice!!
I will use stright madiface with exprescard.
Jarek
Logic 9 is not enough stable to record 64 tracks with madiface in my opinion. Therefore I do it very often (64 tracks with madiface) with Nuendo 4.3.
5
It's happened. I did 64 tracks  with Madi, MBproo and SL OS.
I record more than hour in one pass. Just recording.
There is a few cons but its problem with Logic 9 not with RME.
This card is impressive.
Thanks!!! RME
Jaroslaw Regulski
Depeche Modes FOH engineer Antony King recorded every show with MADIface and Reaper (64 tracks) on an ordinary VAIO notebook without any problem. Reaper seams to be very stable - at least in the Windows version.
best regards
Knut
